P0174 code, Discovery II
Old Mar 6, 2010 | 11:00 PM
Willie00d2's Avatar
Default P0174 code, Discovery II
I just finished doing a head gasket job on my 2000 Discovery II. It started right up, runs good and no leaks. I noticed a slightly rough idle. So I read the codes and came up with a P0174 system too lean bank 2. Could this be a bad 02 sensor. I did spray the cylinders with oil to prevent rust, maybe that fouled a sensor. I replaced the 2 front sensors about 80,000 miles ago, the rears could be original. The Maf has about 80,000 on it too.
Thank you,
Willie
2000 Discovery II
181,000 miles
Old Mar 7, 2010 | 06:16 AM
Rovin4life's Avatar
no, not a bad oxygen sensor. Could be a maf sensor. if you have a code 0734 or 733 with it then yes its a maf sensor. But if you don't double check you tightened the intake and exhaust bolts down. seen a few of them get loose causing issues after a head job.
sayeedA
Nov 15, 2011 11:02 PM
jrm123180
Oct 10, 2011 12:19 PM
OldBob
May 17, 2011 05:10 PM
tbesselman
Nov 9, 2010 02:33 PM
hriant88
Apr 30, 2008 07:33 AM
