P0300, P0305, P0307, p1319 blink SES Light
CORRECTION: P1300- not P0300.......4.0L Bosche engine. I have codes P1300, P0305, P0307, p1319 with a blinking SES Light. Sometimes the light doesn't flash, just stays on. I have replaced the plug wires and plugs and cleaned the air filter trying to fix this, but still same trouble. Somewhat smooth idle, but not smooth acceleration. Anyone have any suggestions?
I've seen a bad or failing O2 sensor trigger misfires without causing any typical O2 sensor codes. I suspect that here because the two misfiring cylinders are both on the same side of the engine but 5 and 7 are on separate coils.
Coils can fail, but that's relatively rare on DIIs, plus the probability of both coils failing at about the same time seems remote. I'd be more likely to suspect the coils if paired cylinders were misfiring (e.g. 5 and 8 or 7 and 4). Since the two misfiring cylinders are next to each other a failed headgasket could also be causing the problem.
Try swapping upstream O2 sensors from side to side and see if the problem moves to the even-numbered cylinders. I'd try that before buying and installing coils.
I didn't think O2 sensors could cause misfires but I also haven't had trouble with mine as of yet. If you must replace any sensors, buy OEM BOsch. Cheap, aftermarket parts won't work with BOsch ECU most of the time- plenty of threads on that topic.
bennyb43
11-28-2015 04:01 PM
rtindle1975
06-11-2014 03:05 PM
EVN137
02-25-2012 02:05 PM
rishmoca
01-10-2008 12:05 PM
