P0307
Old Dec 30, 2006 | 05:12 PM
JBRIII's Avatar
Default P0307
changed my plugs today to Bosch +4's and now am throwing code p0307 which is cylinder 7 misfire. Checekd the plug and wire. Pulled the plug back out and reset the wire. Cleared the codes, but still getting it and P0300 which is general misfire. Any Ideas?
Old Dec 30, 2006 | 07:55 PM
JBRIII's Avatar
Default RE: P0307
I think I tweaked the boot when i pulled it loose. Going to replace the wires and see if that helps. Only getting the code 307 now.
Old Dec 30, 2006 | 09:16 PM
Default RE: P0307
What year truck and what wires are you using?
MIke
Old Dec 30, 2006 | 10:11 PM
JBRIII's Avatar
Default RE: P0307
It's an 02. I guess I'll have to get the wires at the dealer on Tuesday morning. No one locally has any after market. Can't wait for a shipment either.
The delearship I got it from has a 3 month bumper to bumper. They are going to fix it along with the window regulator and the door lock actuator. it's over there now. drove like crap, kept it under 35.
Old Dec 31, 2006 | 11:26 AM
Default RE: P0307
You don't really want to buy factory wires, they are expensive and don't hold up.
See if you can find one used wire to get you by and then order a set of 8mm Magnacor wires. I could get you to a group that would overnight them Tuesday.
Mike
Old Jan 3, 2007 | 04:28 PM
JBRIII's Avatar
Default RE: P0307 -Update
Update - Plug in cylinder 7 had a small crack. Replaced it and cleared the codes. No more problems and running great. Going to save the wires and change them next go round. Dind't feel like taking the manifold off If I didn't have to right now.
Old Jan 3, 2007 | 06:47 PM
Glad to hear all is well again. Try and change the wires sooner then later so you can get as much punch out of those new plugs.
Mike
rtindle1975
Jun 11, 2014 03:05 PM
hatt53
Mar 27, 2013 05:16 PM
Jessica Perez
Jul 7, 2011 10:49 AM
jimbo972
Jul 14, 2010 09:00 PM
mtat
Oct 2, 2008 10:03 PM
