P0441 Again
Unit sits on a black bracket mounted to the intake manifold. From the factory it has two plastic clips that fit over the hoses to keep it in place. If those are broken, simply remove the base (usually that stays after the top breaks off) and just use a zip tie in each location to hold it in the same fashion as the OEM setup.
Best4x4 (05-22-2020)
Let us know if you ever figure this out. I get those codes from time to time
I ordered a smoke tester which I will do intake and hoses leak checked
check your connections and wires going into plug
i know if you unplug it you will get that code pretty quick So I know the system knows it’s unplugged.
Hince why I suggested check the connector where the wires go in.
cvhyatt (06-06-2020)
@cvhyatt I went around on mine too, I kept getting the code every 50 to 70KM, replaced the purge valve with a Bosch unit and replaced the hose clamps so far so good. If you can get your hose off try some compressed air on the intake side into the throttle body, it should flow pretty freely
cvhyatt (05-31-2020)
Is this still using the OEM hose? Does it look cracked? Make sure the nipple on the intake where it connects isn't loose. Also make sure the connector below the purge control valve toward the back of the engine/bulkhead isn't loose. There is an OEM inline bleeder on that line as well never had one leak but make sure the cap is on it. Gas cap securing tightly?
