P0441 pending but purge valve recent
'Been looking for an affordable air cleaner cover, but good to know it's unelated. That Hyundai part is the one i put in back in July.
I did recently remove and reinstall the purge valve to replace the clamps ( https://landroverforums.com/forum/sh...d.php?p=349161). I'll check the connector and its wires then.
Well, I visually checked all the vacuum hoses (i.e., no smoke test yet,) and disconnected and reconnected the electrical plugs. Since these were pending, I just let it go through the EVAP cycle (man, that's a long one - took about a week+) and the codes are gone.
If they return or in the Spring, I'll delve into them further - whichever comes first.
I have the same problem going on. I got a P0441 code on my ultragauge and installed a new purge valve. After a few days the 0441 came back as a pending code. I cleared it a few times but it always came back. I'm going to leave it as a pending code and see if turns into a Trouble Code that trips the Check Engine Light. Maybe I'll get lucky and it will clear itself.
I want to check the line/hose that runs from the Purge valve down the back of the engine for cracks, but I have no idea how to get that thing out without pulling the engine. Any ideas
Disco_Fever (10-31-2014)
