P0447 Is it that big a deal? Related to stalling?
Old Apr 25, 2022 | 08:12 AM
Gnomadf's Avatar
Default P0447 Is it that big a deal? Related to stalling?
It's the persistant code that never wants to reset, and I am not subject to inspections emissions or otherwise, so unless it was likely to actually cause issues I' m not inclined to bother with it.
I am having a problem with the Disco stalling while running, I have replaced the CPS, when it cranks after stalling I get spark as verified with an inductive timing light and when it sits for a period of time from 5 to 10 minutes it starts right up again and runs until it doesn't. Is it possible that the purge valve sticking is causing a vacuum in the tank and the pump can't pull fuel? Seems unlikely that the tank system would hold that much vacuum after 20+ years. OTOH the truck hasn't been run much in the 3 years I've had it and the time the DPO had it, I have no idea of the service history before that, and think it's possible that the tank has accumulated enough crud in it to block the screens in the pump.
Steven Roberts
Nov 4, 2021 10:33 PM
vanbadri
Mar 29, 2019 09:44 AM
Volkov
Nov 3, 2015 06:49 AM
Snafu / Disco Fries
Jun 20, 2011 08:26 AM
green machine
Apr 6, 2010 05:30 PM
