P0453 EVAP Code
Old Jan 30, 2017 | 06:00 PM
tcr6v1's Avatar
Default P0453 EVAP Code
Hey guys. Ive managed to solve my previous engine code problems but now I have this one left. P0453
Ive searched this forum and I havent found much inforamation. My truck needs to get its Ontario emissions test asap and it cant have a engine light on.
Whats the best way to test the FTP sensor and the wiring for faults? Fixing this is on my list of stuff to do tomorrow.
Old Jan 30, 2017 | 06:57 PM
LR03NJ's Avatar
googed, hope this helps
Common Tests for the Evaluating the Fuel Tank Pressure Sensor
Retrieve the code and write down the freeze frame information to be used as a baseline to test and verify any repair.
Pay very close attention to the Fuel Tank Pressure readings by observing its data stream on a scan tool. Does the Fuel Tank Pressure Sensor work properly? If it doesn't, the system will think that no vacuum is being created when, in fact, there is a vacuum being created that the Fuel Tank Pressure Sensor is unable to read. The Fuel Tank Pressure Sensor is the primary feedback sensor that the Powertrain Computer relies on for the leak test data.
Inspect and test the Fuel Pressure Sensor wiring. Verify that there is a 5-volt reference signal from the PCM, a good ground, as well as a good signal return circuit to the PCM.
While observing the data stream change (or lack there of) on a scan tool, test the Pressure Sensor with a Vacuum Gauge while it is connected to the wiring harness.
If all of the above test results are within spec, then the problem may reside in the PCM itself.
Old Feb 1, 2017 | 02:11 PM
tcr6v1's Avatar
Well, I think I've found the problem. Ripped up the carpet in the back to get to the fuel pump and I found the wiring for the tank pressure sensor in this condition....
Time to try to Frankenstein this plug and clean up the leaves on top of the gas tank.
tcr6v1
Jan 28, 2017 07:10 PM
CODisco2
May 13, 2015 03:44 PM
ryanD2
Jun 25, 2009 06:00 PM
Bugman
Apr 27, 2005 01:20 AM
Bugman
Apr 26, 2005 12:32 AM
