P0501 Vehicle speed sensor range
Old Jul 7, 2022 | 06:22 PM
  #21
longtallsally's Avatar
Originally Posted by Richard Gallant
@longtallsally it could be flakey mine would flicker out after about a minute of movement, then just quit. I also found S for sport mode was unreliable (had to find my notes). But it could still be bad, I am not sure if you can check it though.
Got it. And again, thanks! I cleared the code before I left from work (I’m driving it now since the S4 is down from the damn deer) and it didn’t come back- which it has done in the past. This lends precisely to what you just described. I’m going to more or less ignore for a bit as I work through the other stuff needing attention.
Old Jul 9, 2022 | 07:18 PM
  #22
So I did an inspection underneath and found a 2 blade sensor with one unplugged. I plugged it back in and went about some other service. Now the POS thinks there isn’t a MAF hooked up, so I need to diagnose that. I’ll get back to this one eventually…
Old Jul 11, 2022 | 10:53 AM
  #23
OK, I put the old MAF back in and all is well there. Except…. Yep, the P0501 came back. Methinks that switch that I plugged back into is dead. Going to research and replace as that shouldn’t cost very much. I suspect it’s the High Low switch Richard mentioned.
I did a good inspection of all the wiring harnesses on each side of both the tranny and T case and that was the only suspect one. Some of the sheathing wasn’t perfect, but all wiring looked solid.
cvhyatt
Jan 31, 2020 02:31 PM
dwatterson1
Feb 27, 2017 09:35 AM
wizardmagu
Nov 26, 2010 09:55 AM
NAGA
Nov 12, 2010 02:55 PM
rbuisa
Aug 25, 2008 10:17 PM
