p1158
Old Mar 15, 2010 | 09:26 PM
DDP's Avatar
DDP
Default p1158
i have a code two times both are p1158 ive rotated o2 sensors and still get this codes can someone advise what to look for
Old Mar 16, 2010 | 09:44 AM
okdiscoguy's Avatar
So you moved the sensors in front and back? What is your mileage? Have you followed the wires back to the loom? The front sensor wire can lay on the cat if you aren't careful.
Old Mar 16, 2010 | 11:04 AM
You are running rich on "B", have you checked for vacuum or exhaust leaks, one will probably be the problem.
If still there, get a scanner that can actually read sensor signals and see what your are doing.
Old Mar 16, 2010 | 01:32 PM
rj95lss's Avatar
Good call, I have rerouted the wiring for both the front sensors to keep them out of harms way.
jeffrudy
Jul 27, 2010 12:24 AM
osolupo
May 18, 2010 11:45 AM
