P1170 code--O2 sensor
Old Mar 13, 2012 | 04:21 PM
kpl1228's Avatar
Default P1170 code--O2 sensor
I guess I'm going to replace the O2 sensors after reading the Forum and seeing a P1170 code on my Ultragauge (along with the P1590 3 Amigos).
a) can I wait till Friday to do this AND drive it?
b) is it DEFINITELY O2 sensor(s)?
Old Mar 13, 2012 | 04:57 PM
EVN137's Avatar
IIRC (P1170) you may wanna go underneath and check for leaks in the catalytic
converter before changing the O2 sensor. There's a post here about it. Do a search
On P1170.
i know this is an old thread but the problems with the p1170 code --is ussually a hairline crack in the weld at the front of the passenger side(bank 1) converter-it spans across the top of the converter and can only be seen with a mirror--it can be fixed with simply running a bead weld acroos the top of the converter(you must drop the exhaust to gain access to it)
or
if your vehicle is still within the 8 or 80 manufacturer's emission warranty the dealer should replace it for free as per the federal gov't
By LandRoverLuke
I had the same issue.
Old Mar 14, 2012 | 07:24 AM
My money is on your 02's and with your mileage, changing them all out will improve your performance and mileage.
Old Mar 17, 2012 | 02:53 PM
kpl1228's Avatar
another quick question: can I get the generic O2 sensors at the loocal auto parts store for $20 (x4), or the OEM for $60 (x4)? I agree that OEM is often best but the money's tight lately
Old Mar 17, 2012 | 08:26 PM
EVN137's Avatar
I personally have used the O2 sensors from AB. I have no experience with generic O2 sensors. I know they are available, they usually have a pigtail that you have to splice
your old connector to. I have read posts here about others using them. try doing a search on it.
Given your mileage, you'll probably need all 4 sensors. At 90K miles, they've reached
their expected usefulness. Their declining performance is what triggers your MEL along
with other things. Gotta check other causes.
If I were in your shoes, and springing the 60 is a reach, try swapping just the affected
pre and post catalyst. The code usually clears after 2 driving cycles. If it works out
then swap the other side. If you get 30K miles from them, then you've reached your
break-even point ( 30K / 90K = 20 / 60 ).
Make sure you solder your leads well and use shrink wrap.
Maybe someone else will chime in.
All the best.
Ed
Old Mar 17, 2012 | 10:15 PM
ralphobell's Avatar
I replaced all 4 of my O2 Sensors with OE equivalent Bosch sensors which I picked up from Oreilly's Auto Parts. Your looking at $280, but I believe it is very well worth it. No splicing. Hardest part is unplugging the pigtails.
Old Mar 18, 2012 | 08:23 AM
What you are calling generic are not that but universal in that they have no plugs which means you will need to attach your old plug assembly to them, so no, do it right and buy any brand of 02 with plugs attached, Amazon has some great prices on 02's.
Old Apr 9, 2012 | 06:59 PM
kpl1228's Avatar
Money's very tight right now, so I went ahead and bought a used set of 4 on ebay from a junked 03 Disco, cost me only 70 bucks total. They look in great shape. But they are a little dark from carbon.
Is there a way to clean these or, due to the sensitivity, is this an absolute no-no? If I can clean em, what do you guys recommend? Or should i just stick em in and see what happens?
Old Apr 9, 2012 | 07:43 PM
Looks are nothing when it comes to 02 sensors, a good OHM meter and follow the testing procedure is the only way to tell if they have any life left in them.
Old Apr 10, 2012 | 10:52 AM
FightOnUSC79's Avatar
Had same code on ultra-gauge, checked for leaks in exhaust, no dice, so I bought new sensor on ebay (Bosch) for 40 a piece shipped. Pooped em in and code has been corrected. Good luck.
ps. Do it right the first time and save the headache.
HSEJavaBlack
May 3, 2023 11:55 AM
firefihter23
Oct 3, 2013 03:44 PM
JBEGIN
Aug 8, 2009 08:03 AM
Frank4
Feb 24, 2009 05:36 PM
pops918
Jan 16, 2008 01:47 PM
