P1171 and p1174?
Old Aug 23, 2013 | 05:59 PM
sickws6's Avatar
Default P1171 and p1174?
Lean codes. What procedure in finding cause? Thanks. I have searched and found tons of things but where to start first?
Old Aug 23, 2013 | 07:15 PM
Any other codes along with those? Start with a vacuum leak check and see if any other codes show up, if they do get back to us with any new numbers.
Old Aug 23, 2013 | 10:01 PM
sickws6's Avatar
No other codes just those 2 and sometimes only 1171
Old Aug 23, 2013 | 10:02 PM
sickws6's Avatar
I'll check for vacuum leaks in the morning
Old Aug 23, 2013 | 10:54 PM
Jared9220's Avatar
I had the same codes and after a smoke test with a cigar I found I had a small vacuum leak where the air intake tube connects to the throttle body.
Check out this thread I made awhile back to help you out.
https://landroverforums.com/forum/di...s-cigar-54235/
Old Aug 24, 2013 | 07:12 AM
acamato's Avatar
I had the same codes also. Usually 1171 and sometimes 1174. Mine ended up being the intake tube also.
Old Aug 26, 2013 | 08:30 PM
sickws6's Avatar
Nice tightened up all intake hoses no more codes yet after 3 days of driving. Thanks y'all
Old Nov 6, 2013 | 09:22 PM
sickws6's Avatar
Back now getting 1171 1174 1412 and 1415
Old Nov 8, 2013 | 07:49 PM
xxdoylexx's Avatar
OK this issue is caused by three major possibilities
1. Bad fuel pressure. ...
major cause would be a bad fuel pump and/ or filter.
2. unmeasured air going in the the cylinders,
major cause a vacuum leak
3. the meter that measures air not working
major cause MAF or MAF plug
First thing to do is to get a good code read, a code could help you pin point the issue, an example is a scanner can tell you is the signal from the MAf is is present. bad or intermintant.
Next smoke test your air intake. this is a good video that explains vacuum leak possibilities
finally have some ine pressure test your fuel.
Old Nov 8, 2013 | 08:11 PM
xxdoylexx's Avatar
Finally this video explains the lean on both banks issue,
the p0174 and p0171 are the same as the two you have
