P1171 and p1174?
Old Dec 14, 2013 | 01:18 AM
TRIARII's Avatar
Im getting same 2 codes. P1171 has been around for awhile, Ill clear it then after a week or so it comes back, today both P1171 and a new code P1174 popped up. Ill still trying to track the causes for my fault codes. Good luck to you and let us know what you come up with.
Old Dec 14, 2013 | 07:57 AM
lmcgrew79's Avatar
After doing the cigar smoke test, mine was the push lock fitting on the intake manifold.
Old Dec 14, 2013 | 07:24 PM
DiscoDubs's Avatar
Mine ended up being caused by deteriorated injector o-rings. Figured it out after several vacuum leak test with brake kleen. Sprayed in the valley directly at injectors for 1,2,3,4 which you can see from top of engine and reach with a straw on the spray tip.
vishrb
Mar 10, 2015 06:21 PM
ycc456
Oct 28, 2013 12:43 AM
bwilliam
May 14, 2012 12:09 PM
Dino76
Aug 3, 2011 08:48 AM
steinj
Jun 29, 2007 05:58 PM
