P1179
Old Jan 28, 2008 | 09:03 PM
rcendo's Avatar
7th Gear
Default P1179
Got a check engine light with code P1179 - AMFR Correction at max negative value.I have a 98 Disco with 80K.
What am I dealing with here and where do I start (or does the shop start!)
Thanks
Rik
Old Jan 28, 2008 | 11:04 PM
wesk's Avatar
Default RE: P1179
I would start with simple stuff first. Check the air filter for debris then pull the MAF. Clean the MAF and while you're at it, hit the T-body with some cleaner too. If that doesn't do it, move on to O2 Sensors and Fuel Filter. Others will chime in with other suggestions.
-W
Old Jan 29, 2008 | 08:09 AM
okdiscoguy's Avatar
Default RE: P1179
ORIGINAL: wesk
-W
NEVER try to clean the MAF on a D2.
Old Jan 29, 2008 | 08:51 AM
Default RE: P1179
Even on a D1, don't clean the MAF just to be cleaning it, do it only as a last resort when you actually have MAF fault codes, including lean cylinder banks and either a 3rd. or 4th. gear out of ratio.
Check every spot for vaccum leaks for sure.
Old Jan 29, 2008 | 08:52 AM
wesk's Avatar
Default RE: P1179
Cleaning the MAF on a D2 damages it?
Old Jan 29, 2008 | 03:20 PM
okdiscoguy's Avatar
Default RE: P1179
ORIGINAL: wesk
**YUP** That is why K&N air filters are not recommended. The Bosch MAF's are too sensitive.
Old Jan 29, 2008 | 05:34 PM
wesk's Avatar
Default RE: P1179
So what kind of Air Filter should be used?
Old Jan 29, 2008 | 05:47 PM
okdiscoguy's Avatar
Default RE: P1179
Regular paper from the dealer. I use WIX filters. Another deal with K&N is that they let more air through...They have less surface area, so to me, more air, more dirt. Also, more air, more fuel. If you were dragging the car, and needed the extra HP, might be something. I had a K&N on mine and ditched it when I got on here 2 yrs ago. I noticed no difference, and have heard of people getting better mileage without it.
Old Jan 29, 2008 | 06:01 PM
Default RE: P1179
Just go to any auto parts store and buy a name brand filter. K&N filters just are not worth the money. It would take you forever to recup your money in MPG. And if you ruin your MAF then you will never recup your money.
Old Jan 29, 2008 | 10:49 PM
rcendo's Avatar
7th Gear
Default RE: P1179
Interestingly enough I have a K&N Air FilterI put in over Christmas.....So in addition to checking for vacuum leaks should I replace the filter with a regular one?
Thanks
Rik
