P1179
Old 01-30-2008, 01:16 PM
OxyCoRover's Avatar
Default RE: P1179
Yes I learned the hard way with my K&N Airfilter, I get a P1178 error code on mine, working from cheapest to expensise which is Fuel filter, o2 sensors, then MAF
And on the o2 sensor there are 4 which i found range from 177 dollars to 55 dollars, the MAF is 700 + dollars if new, if you get a used/refurb you can spend 10 to 250
Hope this helps
Old 01-30-2008, 06:56 PM
okdiscoguy's Avatar
Default RE: P1179
ORIGINAL: rcendo
Interestingly enough I have a K&N Air FilterI put in over Christmas.....So in addition to checking for vacuum leaks should I replace the filter with a regular one?
Thanks
Rik
Was it pre oiled, or did you do it yourself? A D1 MAF for the most part should be ok, they are nore durable (hence the $600 price tag)
I would swap it out with a paper one and see how it does.
TheRealMW2Ninja
07-22-2011 12:40 PM
Spencerfitch
02-06-2011 01:07 PM
RoverRover1
04-26-2009 10:48 AM
willlane
07-13-2008 10:28 PM
Craig
07-06-2007 05:00 PM
Quick Reply: P1179
