P1314 Come On
Old Feb 12, 2009 | 12:42 PM
azazel_18_2's Avatar
Default P1314 Come On
My truck now throws a code 1314 which is cat converter. I have a backpressure gauge and it reads 1psi back pressure on both sides. I am getting tired of working on this thing but I have no choice but to continue fixing her. Any ideas?
Old Feb 12, 2009 | 02:20 PM
Default RE: P1314 Come On
Sure, how many miles on your truck and what went wrong with your right bank, cylinders 2,4,6, and or 8 that caused the cat to fail?
Depending on your miles, you can replace one or both, pretty cheaply.
Old Feb 12, 2009 | 02:48 PM
okdiscoguy's Avatar
P1314
Land Rover
Misfire Likely To Damage Catalyst, Bank B
Doesn't mean your cat is bad, just that you had a mis-fire that could damage your cat.
How many mles?
When was the last time you changed plugs and wires? and with what brand?
Old Feb 12, 2009 | 03:20 PM
"Likely" is not in the fault code for a 1314, "Damaged" is.
Old Feb 16, 2009 | 03:24 PM
One thing I forgot to say is when I put the plug wires on it was dark outside. All I had was a flashlight and eveidently I mixed up wire 7 and 8. Put them on the right coils and reset the code and it runs like a dream and no code. Next up, blower motor issues.
JoeyDisco96
Jul 1, 2020 10:50 PM
twilightcall
Jul 1, 2020 10:31 PM
Cosmic88
Mar 9, 2011 06:53 AM
Buzz09
May 6, 2010 01:55 PM
hotdogpimp
May 11, 2009 01:35 PM
