P1413 Code
Old Jan 21, 2010 | 08:42 AM
brooksa's Avatar
Default P1413 Code
I posted this on LRO and all I heard was crickets???
I have been getting a P1413 SAI code that keeps popping up, it will stay on for a week or so then go off and couple days later come back on. I just replaced the heater plate gasket and one of the hoses to the SAI control valve was really loose so I made all was tight and still throwing the code. I have searched and read the few posts that were related and one of the solutions was to take off and clean the SAI valve which brings to my question; What do you clean/rinse the valve out with? Will a carb cleaner be ok or?? any help?
Old Jan 21, 2010 | 09:02 PM
CSPM's Avatar
5th Gear
Concerning your 1413 Code, I just experienced that same error and my local Indy mechanic replaced the secondary air solenoid using a BMW part number, said it was cheaper cost only $20 dollars. Part number YDJ100000. Hope this helps out.
Old Jan 22, 2010 | 07:49 AM
brooksa's Avatar
Perfect, thank you for tip, I will take a look at that also.
Old Dec 29, 2013 | 10:29 AM
redwhitekat's Avatar
Anyone know where this secondary air solenoid is located on our trucks I got an 04 and every month I get a p1413 code
sayeedA
Nov 15, 2011 11:02 PM
salvine
May 22, 2011 07:11 PM
agthird
Jan 19, 2011 02:56 PM
mahoney87
Jul 21, 2009 07:05 PM
mahoney87
Jul 16, 2009 05:49 PM
