P1590
It’s related to the ABS system, and is a general fault. You’ll have to scan the ABS system to see if there is an ABS fault that triggered it.
Mine throws that code constantly, but it doesn't trigger the CEL.
In case you can't read ABS codes, my ABS system gives me a shuttle valve error and a wheel sensor error. I never get the three amigos but I expect they will show up sometime unless I clean/replace the wheel sensor and do Option B.
