Are P38 4.6L Ranger Rover Engines Interchangeable with Discos?
Old Nov 27, 2009 | 01:25 PM
meltdowndave's Avatar
Default Are P38 4.6L Ranger Rover Engines Interchangeable with Discos?
I know that the 4.6L engine was introduced to the Disco in '03. From what I've read, Land Rover used another vendor to provide these engines around the same time, hence the machining problems that cause oil pump issues for the 03s and, in some cases, the '04s.
I've been searching for '04 Disco engines only when it comes time to replace my '03's engine. Those are a tad too expensive for my taste.
Now, I'm wondering if I can also widen my search to low mileage '99-'02 P38 Range Rover engines as well?
What about Jaguar?
So long as I get a Bosch engine with secondary air, are there any concerns about going this route?
Old Nov 27, 2009 | 01:42 PM
AK Rover's Avatar
As long as you don't change anything with the emissions system you should be fine swapping in any 4.6 you find.
Old Nov 27, 2009 | 01:54 PM
Was just checking out AB.
It looks like the oil pump and front cover might be different. Other than that it looks ok.
Old Nov 27, 2009 | 01:57 PM
AK Rover's Avatar
As far as I know all Bosch engines used the same front cover and oil pump regardless of which Rover it was in. Rover did make a GEMS version of the 4.6 also.
rockcity
15
Dec 29, 2010 05:59 PM
donvalencia
Audio/Visual Electronics
May 26, 2006 12:58 PM
01greendisco
Oct 12, 2005 01:14 AM
donvalencia
Jul 8, 2005 02:19 AM
brino
Apr 11, 2005 03:46 PM
