Pain, suffering and wheel sensors
Old Apr 9, 2014 | 03:50 PM
dusty1's Avatar
is your truck minus the plug style connectors?
Old Apr 9, 2014 | 04:17 PM
MarkSF's Avatar
Mine has them on one side, but not the other.
Old Apr 9, 2014 | 04:23 PM
dusty1's Avatar
interesting, so do the new sensor wires come in a super long length or just a patch?
Old Apr 9, 2014 | 04:34 PM
MarkSF's Avatar
I looked at PartsGeek, they have both kinds - one with a short lead and a plug, and one with a very long lead that goes all the way back to the bulkhead. I also found a TSB that discusses replacing all the leads with connectors with the new type, supposedly to improve reliability.
Old Apr 9, 2014 | 04:50 PM
dusty1's Avatar
Cool, thanks for that. I think I'll get one so I can make longer extensions.
Old Apr 10, 2014 | 05:21 AM
Ghaniba's Avatar
The first rear sensor I got literally had 1.5' of wire if that. The 2nd rear sensor I had was long enough to run from the passenger side, to the drivers side, up the frame rail, up into the engine bay, cross the top of the engine and down into the passenger footwell through the firewall. I opted to run it along with the other cabling along the passenger side frame rail. Trimmed off at least 8' of wire doing so.
I'm assuming LR opted to just replace the entire line because of a few connector issues. Those little connectors they use aren't anything special, and getting rid of -all- connectors obviously solves any connectors going bad. If my rear drivers side goes, I'll try the short one and see my success, if not, I'll buy one of the full solder in style again.
On another note... I spent 3.5 hours yesterday on the front left and changed out my wheel bearing. Cleared the codes last night and went to bed. This am - Got up and drove it to work - 52 miles... ZERO ABS LIGHTS!!! Hurraaaaay! Now, I've got a spare front solder in sensor and a plug in style for the rear drivers, if they go! Yay spare parts!
Dave
Old Apr 10, 2014 | 07:21 AM
drowssap's Avatar
Ghaniba,
thank-you for the heads up, a lot of people would not have admitted it and blamed it on a bad supplier.
Ghaniba
Jan 15, 2015 02:55 PM
vishrb
Nov 19, 2010 12:09 PM
salve7
Nov 17, 2009 05:43 PM
meltdowndave
May 2, 2008 10:10 AM
dmacd
LR2
Nov 3, 2007 03:26 PM
