Paint Damaged Disco Project
We finished today including installation of the restored old bumper cap.
LINK: for the land rover color
Spray Paint | Aerosol Touch Up | AutomotiveTouchup
I think you should get more Gloss Clear Coat 1:1.5
With the end cap, I dremelled with cutting tool to scrape about an inch around the crack in the back and used JB Weld epoxy. If you have to apply bondo, make sure its completely dry before prime it before the color coat or it might bleed through the paint or the patch work will show in time.
Sand the original paint with 800 then use base coat. Spray several coats and sand it with 2000 until minor paint dusting is smooth to touch. Apply clear gloss when totally dry. Run 2000 again then buff or buff without sanding lightly.
Corrigan
04-26-2013 02:38 PM
kennims
04-18-2005 10:35 PM
