Painting your Wheel Arches
Sorry if I'm late on this thread.. the issue with the arches is that the black coating on the nylon wears from sundamage. I'm not sure if its a dye that is coated or a rubbery-like thin coat. If you feel the arches, they are rough under the coating. Back to black cant make white nylon black lol. My arches look like crap too.
If you want to totally change the look, and never have to worry again, I came up with a plan for my own Disco and I'm happy to share what I am doing. There is a seller on eBay that sells factory matched 12oz cans of spray paint. You can match the truck, or stick with a satin black. If you buy a single stage satin black spray can, it wont be as good as using a flat black base coat, and then top it with a satin clear. The satin clears have dulling agents, so when you wash or wax it wont get smeary or shiny.
Another thing, Krylon Fusion is good for plastic and cures rock hard, but the way it applies is very grainy even if taking the right steps to prep. I'm just not a big fan of it when trying to do a really great job. SEM makes better trim paint, and I would suggest using that over fusion.
No matter what paint you use, buy a can of adhesion promoter which is like a pre-primer/ primer. I would still use a primer, self etching is best. Make sure to clean the arches well, and do not use paper towel because that rouch nylon will just make lint out of it and it will stick on the nylon and you don't want to paint over that, but might not be an issue after you sand them down. I can't tell you yet from experience.
Bottom line, the arches are no different than bumpers. Plastic can be painted, and has been done forever so it's no black art. Its all about the prep work to ensure adhesion.
goodluck
goodluck
bedliner
My bfriend just painted his bumpers of his classic with the bedliner spray, just like spray paint. it looks awesome, sorry i don't have pictures. it looks perfect for the arches, and that's exactly what i'm going to do to mine. whoever had my truck before me did a fantastic job messing them up, part of it's rough, part of it's sanded, part gray, part black, paper towel crap is in there...it's awful. but the stuff in the spray can is nice, it comes out thinner than the actual rhinoliner stuff. which is also a nice look.
WMustian
07-06-2012 12:02 AM
