Park brake won't release
Old Jul 9, 2012 | 11:18 AM
Bkreutz's Avatar
Originally Posted by Draayer
If I remove the driveline, will that allow me access into the drum or is there more to it?
Thanks,
After you take the driveshaft off, there is (or was) a phillps head screw that will be under where the driveshaft was bolted on, then it slides off the 4 studs. BTW have you tried adjusting the parking brake? It is not an automatic adjusting mechanism, there is an adjustment bolt on the front side of the backing plate. (if you don't have the RAVE manual I'd suggest downloading that, it covers this procedure)
amer_qureshi
Jul 10, 2024 02:03 PM
ljdiscovery
May 24, 2020 01:32 PM
bikingteacher
Jun 19, 2015 04:23 PM
PiperC
Jan 13, 2012 02:17 PM
nicademus
Sep 30, 2011 06:45 PM
