Parking light problemo
Thanks spike, side marker light front drivers side has corrosion all over the inside sprayed it with wd40 and tried to clean it out best i could, light works but some times goes off, i had the same problem with the pass. Side instead of buying a new socket i just spliced the wires to the bulb. Maybe the socket is the problem. We shall see.
Like your message, people are scared, like sheep
down with the new world order!
Thanks man, i do have a corroded driver side marker, maybe thats it, i tried to clean it w/wd40 but still lights a bit shakey. Had to splice wire to bulb on pass. Side for same reason. Know where to get cheap bulb sockets for side markers anywhere? Thanks , mark
You can buy a new bulb socket for not much money.
www.atlanticbritish.com
I had to replace both of my turn signal sockets in my rear bumper.
hey fellas thanks for all the info! got it fixed, it was the front drivers side marker socket.
appreciate all the info, and yes it was #8 dash fuse
appreciate the help,
by the way i replaced the flywheel due to a grind sound but its still there, not often but once and awhile, any ideas?????
You replaced your fly wheel because of a grinding noise when you start the truck?
The problem is your starter not the flywheel.
Replace your starter ASAP or you will be replacing your flywheel again.
The starter is chewing up the teeth on the flywheel.
I was told the starter was fine and wasn't missing any teeth, can a starter be BAD with all teeth intact? I was told the flywheel was bad by a mechanic who wanted 800.00 to change it. I actually had it replaced for next to nothing by a friend. The old flywheel had alot of chips on it and it was worn but wasn't missing any teeth. ??????
tibyABv6
Dec 18, 2012 10:09 PM
