Sponsored by: CARiD
RH Parking/Signal light remains on
Old Sep 18, 2006 | 02:55 PM
mathix's Avatar
4th Gear
Default RH Parking/Signal light remains on
I have a 1996 Range Rover 4.0. The RH Blinker/Parking light stays on all the time. This problem occured last night. it has 77K miles on it and so far this is the only problem. I tried replacing the bulb and nothing. I also cleaned some of the ground connections. While working on the car, I noticed the doors would lock on their own after 15-20 secs with the doors open. Any assistance would be helpful.
Old Sep 18, 2006 | 04:23 PM
Default RE: RH Parking/Signal light remains on
ORIGINAL: mathix
If you use the turn indicators or hazard flasher, what happens?
As for the doors locking by them selves, is this something new?
You might want to try and reset your alarm system by locking and unlocking the drivers door slowly with a key, 3 times. May also be the problem.
Mike
Old Sep 18, 2006 | 04:27 PM
mathix's Avatar
4th Gear
When using the signals, they all work except for the RH. The RH just remains on all the time. I thought ground problem, but at this point I'm not sure. Any suggestions? As for the alarm, I'll try to reset.
Old Sep 18, 2006 | 06:18 PM
Let me know if anything changes after resetting the alarm.
Mike
Old Sep 18, 2006 | 06:51 PM
geoman's Avatar
I've seen this problem once before, but the root cause is not something you are gonna want to hear. It was a bad BECM (Body electronic control module) and the cost of the part and re-programming is crazy (like $1500). This P38 Range Rover had the same RF light staying on all the time. The owner elected to just pull the bulb and live with it.
Geoman
Old Sep 18, 2006 | 07:00 PM
mathix's Avatar
4th Gear
I reset the alarm and seems to be working fine. The RH light still stays on. Is it a bad BECM?
Old Sep 18, 2006 | 07:30 PM
ORIGINAL: geoman
Geoman
That is a painful OUCH!!!
I haven't heard of this little quirk before, OH WELL, live and learn.
Mike
Old Sep 19, 2006 | 05:59 PM
mathix's Avatar
4th Gear
Now what if I route wire(s) from the Right Rear Signal/parking light? Could this affect the BECM?
Old Sep 19, 2006 | 06:53 PM
geoman's Avatar
I wouldn't mess with trying to "out-think" the BECM. It is a very complex logic and distribution unit that completely controls switching of signals and current throughout the vehicle. It is packed with fuses, relays, transistors, and microprocessors You mess with sending current to places unintended and you risk losing other functionality in your RR.
If you still want to "give it a go" then see this link for what you are up against: http://www.rangerovers.net/repairdet...ecm/index.html
Geoman
www.eurotekapg.com
Old Jan 23, 2019 | 11:10 PM
redpepper70's Avatar
4th Gear
how do you reset the alarm? I have LR2 and my front side rear / light for signal is on all the time. (engine on or off)
DylanT1233
Mar 28, 2016 05:48 PM
Kalev
May 19, 2014 05:05 PM
smoker
Mar 12, 2012 05:59 PM
DiscoveryHouston
Nov 14, 2009 11:07 AM
owen172
Dec 13, 2006 09:54 PM
