Parts Diagram
I have searched the site and the internet with no luck. I am looking for a drawing(s) showing suspension and frame parts with names and/or parts numbers for a 04 Discovery. Any suggestions? I like to have proper terms in a post. Thanks, SPERAN
Current question: What do you call the tubular cross frame support under the radiator?
Second Question: Does anyone sell bolt and fastener kits for these cars? I have found a packaged kit to be much cheaper than over the counter. I am going to work through the entire underside of the car removing panels, checking/repairing/painting any surface rust - Florida car - looks minor now, but I hate rust of any sort.
In addition the the RAVE manual package that you can download, some vendors, like Rovers North, have on line catalogs with exploded parts diagrams.
Surface rust is normally not a problem under older Rovers..... the automatic corrosion inhibit system usually starts leakin....err, working, before 100K miles.
This is an online version of the Microcat. Once there click on English version. If you want a stand-a-lone version you can download it here. Works great on Windows XP but for Vista or Windows 7 you will have to run it in Compatibility mode.
Here is what I called it when I took it off my 03 to install the steering/brush guard. I figured 1\4" steel is way stronger than this tube.
330585050414 Land Rover Discovery II Front Lower Bar Brace 99-04
roverintherocks
Dec 8, 2010 10:36 AM
