Parts question
Old Nov 25, 2014 | 10:30 PM
clint70's Avatar
Default Parts question
I was looking for consensus on parts... I am looking at parts for my 02 Land Rover and there are OEM one and they usually double the after market parts. What has been the experience with these parts? Are the OEM worth the extra $$? If I can save some and not affect the overall functioning... I am all for it. Thanks for the help.
Cheers!!
Old Nov 26, 2014 | 05:29 AM
potxoli's Avatar
I think that depends on the part. You should ask here on a case by case basis. For example, I tried cheap MAF's, kept getting constant check-engine lights, finally purchased OEM Bosch unit and the problem went away.
However, for a radiator issue I had, the consensus was that a relatively cheap aftermarket unit was very good quality.
Also, this thread about the general quality of aftermarket suppliers might be of help:
https://landroverforums.com/forum/di...-turner-70286/
Old Nov 26, 2014 | 06:12 AM
drowssap's Avatar
BritPart is low end, but a mentioned a lot has to do with the part itself.
that say i have never gotten a really crappy part from any of the bigger suppliers like Atlantic British or Rovers North.
Old Nov 28, 2014 | 03:58 PM
Babymog's Avatar
Remember that OEM might not be the same part as when your truck was built, they have gone through Ford and BMW ownership to TATA and the tools can move to lower bidders to produce, etc. This is common when automotive parts go from production to service parts.
I like to stick to major names (ex: Bosch), but even that can be subbed to another supplier.
Old Nov 29, 2014 | 06:03 AM
G Reeves's Avatar
Stay away from BritPart, or Sh*tPart as they are more commonaly known. Other aftermarket parts like Bearmach are good but difficult to find in the US. There are a number of LR suppliers like lucky 8 llc, Atlantic Britsh to name a few who are reputable and have good customer care with sound advice.
Disclaimer, I work for neither company nor do I reprresent either company but I have had excellent results from both of them
Old Nov 29, 2014 | 04:32 PM
OffroadFrance's Avatar
X1. It really does depends on the part. Many Britparts are total cr@p and false economy. Critical parts or those that are hard to access later I would always use quality parts, typically, driveshaft rebuilds using GKN or Hardy Spicer. Engine parts, transmission seals etc I always use OEM or LR. Bolt on pretty bits I can tolerate cheaper aftermarket parts. Bearings always SKF, Timken etc, top quality makes and they're not a lot more $$$$.
Checkout the comparative prices, you get what you pay for!!! http://www.rimmerbros.co.uk/SubCateg...overy-2--m-292
avo8230
Apr 27, 2015 12:51 PM
roverintherocks
Dec 8, 2010 10:36 AM
Jigsaw89
Oct 18, 2010 07:53 PM
yuenie
Nov 30, 2008 09:53 PM
