passenger side even cylinders running rich... old plugs on that side only black
Old Mar 14, 2010 | 10:06 PM
elboy0712's Avatar
Default passenger side even cylinders running rich... old plugs on that side only black
passenger side plugs came out sooty and black and it was all 4 of the even cylinders.... i did previously have a misfire going on on 8 but that is resolved. also when i had my ignition coils off all the odd cylinder posts on the coils looked nice and shiny where as the even ones looked as though they had been burnt by the heat from the ignition circuit to the plug.. it was really weird
Old Mar 15, 2010 | 07:24 PM
elboy0712's Avatar
bump!
Old Mar 15, 2010 | 08:24 PM
Sounds like a bad O2 sensor.
O2 sensors are what tells the ECU how much fuel is being used on that bank.
Old Mar 15, 2010 | 10:17 PM
elboy0712's Avatar
interesting, i did just replace those at the same time as my new plugs. think i should drive a few hundred miles then pull them to check for charring?
Old Mar 16, 2010 | 09:47 AM
okdiscoguy's Avatar
Yup. You may want to call a local indy shop to have your adaptive memory erased so it will read the new sensors sooner.
ZB-30
Nov 27, 2013 07:47 PM
GiGi La Luz Ramone
Aug 31, 2013 04:46 PM
Spencerfitch
May 3, 2010 02:56 PM
jrmnw1
Mar 21, 2010 06:33 PM
Tibbs
Oct 2, 2005 12:08 AM
