Pcv help
Old May 14, 2023 | 05:11 PM
Mullins.cody's Avatar
Default Pcv help
How do you get this little guy out?
pcv
Old May 14, 2023 | 05:20 PM
andino's Avatar
I grabbed it with some locking pliers and wiggled/twisted until it came out. Be careful not to mangle it too much but it'll come out with some wiggling. It's just friction fit in there. You can try some heat to help as well if its being really stubborn.
Old May 14, 2023 | 05:28 PM
Unfortunately someone broke the nipple off🤦 so now I'm kinda stuck
Old May 14, 2023 | 05:29 PM
andino's Avatar
You can pull the whole metal tube out and then drill out the plastic pcv. You'll want to replace with something like an FV308 (there's a diy by best in the sticky)
Old May 14, 2023 | 05:36 PM
Will the tube go back in if I pull it out?
Old May 14, 2023 | 05:40 PM
andino's Avatar
Yea as long as you don't mangle it too badly. I did the same with mine because 03/04 trucks need the tube to be drilled out to get the correct flow with pcv mod. Look for the thread and it'll have photos and instructions to get it back in.
Old May 14, 2023 | 10:58 PM
mollusc's Avatar
You can also try driving a drywall screw into it and then using that to pull it out.
Old May 15, 2023 | 12:01 AM
Ended up just pulling the tube out, came out pretty easy. I bought another plastic thing to put in there but realized with the pcv mod already done don't need it.
Old May 15, 2023 | 10:02 AM
Xanthro's Avatar
For others having difficulty getting the PVC out, use inexpensive hose pliers from Harbor Freight. They have little round tips to hold the hoses without squeezing the too tight, but tight enough to manipulate. I was having trouble removing the PCV, and got it out in seconds with the hose plier.
WYRover
May 23, 2024 12:06 PM
Best4x4
Jan 18, 2022 04:46 PM
andino
May 18, 2021 12:27 PM
nashvegas
Dec 30, 2020 04:34 PM
