PCV Line stopped having vacuum...
Morning everyone,
Was using seafoam to clean induction. Good suction through the PCV line initially then it stopped. No suction and unable to run remainder of can through. Any ideas what I should check? Only about 1/10 of the can went in before the suction stopped...
Shannon
Shannon
Your line is clogged. Take the hose off and clean it out, then retry. If that doesnt work take a can of carb cleaner and spray directly into the nipple on the side of the intake, the nipple that the PCV hose connects to. The intake side not the engine side.
tsuyoi
Sep 22, 2020 10:37 AM
