PCV Line stopped having vacuum...
Old Jul 29, 2008 | 10:43 AM
cptshanman's Avatar
Default PCV Line stopped having vacuum...
Morning everyone,
Was using seafoam to clean induction. Good suction through the PCV line initially then it stopped. No suction and unable to run remainder of can through. Any ideas what I should check? Only about 1/10 of the can went in before the suction stopped...
Shannon
Old Jul 29, 2008 | 05:36 PM
Default RE: PCV Line stopped having vacuum...
Your line is clogged. Take the hose off and clean it out, then retry. If that doesnt work take a can of carb cleaner and spray directly into the nipple on the side of the intake, the nipple that the PCV hose connects to. The intake side not the engine side.
Old Jul 30, 2008 | 09:19 AM
In his case he should hook into the nipple area just under where the pcv hose hooks in.
tsuyoi
Sep 22, 2020 10:37 AM
searanch
Nov 22, 2011 05:54 PM
jycsalas
Oct 21, 2008 11:49 AM
breal372002
Jun 27, 2007 11:40 AM
dammad
May 8, 2007 12:22 PM
