PCV mod done today
Old Dec 29, 2020 | 07:23 PM
nashvegas's Avatar
Default PCV mod done today
Did the PCV modification today... replaced the stock oil separator and plastic fitting last week. I installed it backwards, I think. But what was bothering me is that it was hard to blow thru the tube w/ separator before I put it in the valve cover. I think I got the spiral thing stuck in crooked?
So, this would be the first ever non stock modification to this Rover, which is fun.
I ***swear*** that the truck idles smoother now... is that actually possible?
When does this ever happen and the tube just falls out and sticks to the hose, not the valve cover?!? I guess a week after you had it out...
F-ing POS
Wala...
Old Dec 29, 2020 | 08:00 PM
escott16's Avatar
Glad you didn’t do what I did and put the plastic part back in and push 3 quarts of oil out of one valve cover gasket
Old Dec 30, 2020 | 04:34 PM
Extinct's Avatar
Entirely posssible it is idling smoother, factory system causes excessive crankcase pressure.
Friday Night Disco
ROAMING WITH FRIENDS
Dec 29, 2018 06:37 PM
TRIARII
Sights N Sounds
Feb 25, 2018 03:22 PM
The Deputy
Dec 9, 2017 01:08 PM
LR03NJ
Dec 4, 2017 12:38 PM
