The perfect engine temperature control combination
Old 07-09-2022 | 11:10 AM
SWM's Avatar
SWM
Default The perfect engine temperature control combination
I recently completed my two main temperature control proactive fixes. The well documented Extinct Inline Thermostat mod @Extinct and the Flowkooler water pump.
My D2 wasn't running hot before the upgrades; but I figured I would take care of it while I was doing coolant flush, hoses, plugs, wires, etc, etc, etc.
Before, I would run about 200 to 203 and occasionally hit 205 but nothing bad above that. Now, after the inline thermostat and Flowkooler, I can't get it to read above 183. I put it thorough some tuff rides; plenty of idling, uphill climbs and is was almost 90 degrees outside.
I'm sure it's overkill to have both but why not
The following 3 users liked this post by SWM:
greisinb (07-09-2022), Richard Gallant (07-09-2022), whowa004 (07-09-2022)
Old 07-09-2022 | 11:23 AM
Alex_M's Avatar
Getting real tempted by those flowkooler pumps next time I need one. I've been inline thermostat for years, but without wiring the auxiliary fan to run when the ignition is on I'll still see 220s on the trail.
Old 07-09-2022 | 11:28 AM
SWM's Avatar
SWM
Side by side with the OEM pump shows it's no contest. Easy swap out and you should get a ton more flow under 3000 rpm
Old 07-09-2022 | 01:46 PM
Richard Gallant's Avatar
@Alex_M do you have a post on your wiring for the Aux fan ?
Old 07-09-2022 | 02:32 PM
DodyDisco's Avatar
Im on this bandwagon as well. Inline mod and Flowkooler water pump.
Here in Las Vegas were hitting about 110 degree weather and I run around town at about 185 190. Freeway I run same temps maybe touching 195.
Installing my new stereo i actually idled with Ac on for a good 30 minutes in this weather only seeing a 203 degree high temp.
Last year without the flowkooler id hit 210 just going through a drivethough line.
Old 07-09-2022 | 08:42 PM
Alex_M's Avatar
I haven't actually finished it the "right way" yet, but I'll try to make one when I do.
Richard Gallant (07-10-2022)
Old 07-09-2022 | 09:59 PM
Dave03S's Avatar
This thread wouldn't be complete without a link to exactly which Flowcooler water pump and which vendor sells it...
Old 07-09-2022 | 10:46 PM
DodyDisco's Avatar
This is the place. If links are allowed. Im prolly breakn some rule im sure. Mah bad
https://flowkoolerwaterpumps.com/pro...8276ee6d&_ss=r
Dave03S (07-10-2022)
Old 07-09-2022 | 11:42 PM
04disco2va's Avatar
Sold on the Flowkooler as well. Wish mine stayed at 181 though !?!
Old 07-10-2022 | 07:33 AM
SWM's Avatar
SWM
I got worried yesterday, it went to 185 for about a second, then back to 181
04disco2va (07-18-2022)
Quick Reply: The perfect engine temperature control combination
