A perfect example of a failed rotoflex....
Old Dec 12, 2009 | 07:47 PM
BajaXJ92's Avatar
Default A perfect example of a failed rotoflex....
This is on my '96 DI....
Was getting some vibes under acceleration so I stuck my head under the truck to check the u-joints and this is what I see. I knew it had some stress cracks in it and needed to be replaced, but I put it off for some reason. If yours has cracks in it, by all means replace it!!!
Cheapest one I could find ($50):
http://www.roverlandparts.com/discov...ouplers-3.aspx
Old Dec 12, 2009 | 08:01 PM
mydisco03's Avatar
Try to get an used drive shaft from a range rover clasic from 87 to 93 i think, they come with u joints and they are very very good,
Old Dec 13, 2009 | 10:13 AM
Why???? When a roto flex can go an easy 100K without needing replacement, much leass they will take a 3" with no problems.
Old Dec 13, 2009 | 11:00 AM
handsome rob's Avatar
$50 is about the best deal you are going to find. I found one at my local wrecking yard that they just gave to me since I have been a lot from them lately for the new Disco 1. You may have some luck on getting a good one since most of the parts I have been buying have been coming off of cash for clunkers that were turned in. There have been perfect grills, interior and just about anything else you would like off a cared for vehicle.
Old Dec 13, 2009 | 02:58 PM
antichrist's Avatar
For $50 it's likely a Britpart one which are known for a very short lifespan.
Old Dec 13, 2009 | 09:23 PM
BajaXJ92's Avatar
Sooooo would you like to recommend another one or just shoot down the cheapest one as crap?
Old Dec 13, 2009 | 09:35 PM
Considering that roverland Parts sells used stuff I am willing to bet it OEM and will be in good condition. I know Atlantic British sells them, I do not remember what they cost there but it somewhere between $80-$100. Buy it there if you are concernced.
RichardBlank
Dec 23, 2008 05:44 PM
DriveAwayDreams
May 21, 2008 07:43 AM
das
Mar 25, 2008 09:10 PM
apcollin
Dec 18, 2006 06:17 PM
iJeremy
Oct 12, 2006 03:21 PM
