perplexing front end wobble
Old Jun 10, 2015 | 08:05 PM
kenk's Avatar
Default perplexing front end wobble
I have been trying to chase down a front end wobble. It is both felt in the front end and in the steering wheel. It started out a minor one only around 45mph. Then progressed to 40-50mph, now I cant go over 35 and hit the slightest bump. I have replaced- track rod and drag link, panhard bushings, steering box with a used unit, all 4 ball joints. Tires have been replaced and rotated and rebalanced.
Any ideas? No play in the wheels, so I'm not thinking hub(s) but???
Also, I notice on diagrams there is a "ball joint tensioner collett" on the lower joint. Maybe?? Thanks!!
Old Jun 11, 2015 | 04:17 AM
Alphamale's Avatar
What about the steering damper? Or, maybe one of the tyres is out of true, try switching them front to rear and see if that makes any difference.
Old Jun 11, 2015 | 04:32 AM
OffroadFrance's Avatar
D2 'Death Wobble' it's well documented internationally.
Possibles causes or combination of causes:
Drag link ***** ends
Track control ***** ends
Steering upper or lower swivel *****
Steering damper
Panhard rod
Watts linkage (rear)
After finding the cause the wheel alignment needs checking and also wheel balance re-checking.
Search the forum for 'Death Wobble' as this is well documented on here and Google.
Old Jun 11, 2015 | 06:18 AM
drowssap's Avatar
the steering damper is the last thing you want to replace, it will just hide your problem.
Old Jun 11, 2015 | 06:33 AM
dusty1's Avatar
How the radius arm bushings doing?
Old Jun 11, 2015 | 06:46 AM
antichrist's Avatar
Yes, suspension bushing possibly.
X2
Old Jun 11, 2015 | 07:33 AM
DustyLBottoms's Avatar
Also check the pinch bolt on the steering shaft:
https://landroverforums.com/forum/di...se-read-45139/
Old Jun 11, 2015 | 07:44 AM
drowssap's Avatar
i have also seen bad u-joint on the steering shaft cause it.
Old Jun 11, 2015 | 08:05 AM
kenk's Avatar
That is something I didn't think of- steering shaft. I know the lower cinch bolts are tight as I just put a new(used) steering box on. I'll check the upper, or maybe just pull it to inspect the u-joints. The radius arm bushings 'look' good-no splitting,cracking,or separating, but are the age of the vehicle.
I guess at least the good is everything I replaced has needed it anyway. I have searched relentlessly hence an almost entirely new front end. Thanks for the ideas!!!
Old Jun 16, 2015 | 07:06 PM
kenk's Avatar
Ok, here's what I found- my panhard bushings are bad. Even though they're only 3 months old. I believe it may be my fault by tightening the mounting bolts too tight and clamping the bushing and not allowing for free movement. Or I could be way off on that. Long story short, should I avoid the allmakes? I found ones by a company called Lemforder, they are twice as much $$. Worth it?? Thanks.
