perplexing front end wobble
Old Jun 16, 2015 | 10:45 PM
dusty1's Avatar
Not sure on the Lem.... Ones
Problem with all makes is in the name. Many manufacturers are under that umbrella.
Are they poly or rubber?
Old Jun 17, 2015 | 05:45 AM
OffroadFrance's Avatar
Originally Posted by kenk
Ok, here's what I found- my panhard bushings are bad. Even though they're only 3 months old. I believe it may be my fault by tightening the mounting bolts too tight and clamping the bushing and not allowing for free movement. Or I could be way off on that. Long story short, should I avoid the allmakes? I found ones by a company called Lemforder, they are twice as much $$. Worth it?? Thanks.
Lemforder are good but not as expensive as LR. Allmakes are normally good but Britparts are iffy (substitute Br.......... for sh.........). Problem with steering woes is that it can be one or a combination of many factors and requires a process of elimination.
Old Jun 17, 2015 | 07:10 AM
kenk's Avatar
The Lem's are rubber. I would have went with the poly, but silly me checked lucky 8 and I didnt see them under the replacement parts. Never thought of looking under the off-road section....
Old Jun 17, 2015 | 08:05 AM
Alphamale's Avatar
Think you're off the track with over tightening the panhard rod bolts RAVE says torque settings for them should be; Panhard rod 230 Nm (170 lbf.ft).
Old Jun 17, 2015 | 04:50 PM
You are supposed to re-load both axles to working weight i.e. axle stands under both the axles on a flat surface, before tightening the Panhard or Watts linkage bolts or in fact any other suspension bolts otherwise the rubber type inserts are 'twisted' once you drop the truck down, checkout the RAVE procedure.
Old Jun 17, 2015 | 04:54 PM
Lemforder are German and are very good quality. They are part of the ZF gearbox group.
Old Jun 17, 2015 | 06:35 PM
kenk's Avatar
Yes, I was just brainstorming on the overtighening idea. I think it was just a bum bushing.
I was going to go with the Lemforders, but after seeing I can get poly ones from lucky 8 at $10 less, plus thankfully they're only an hour away so I dont have to wait on shipping.
I shoulda figured Lemforder was decent quality, i see alot of MB owners use them
Old Jun 17, 2015 | 06:36 PM
kenk's Avatar
Oh, and the last time I replaced the panhard bushings I did it with all 4 wheels on the ground. I didnt find it necessary to put it on stands
Old Jun 17, 2015 | 07:47 PM
CRB357's Avatar
If it isn't that bushing, you still have the CV and Front Propshaft/U joints that could cause your problem.
adigerol77
Apr 24, 2011 11:05 AM
kenk
Feb 15, 2010 09:51 AM
pelias
Aug 13, 2008 04:54 PM
stephenibiza
Defender
Dec 2, 2006 05:36 PM
The Image
Sep 25, 2006 11:05 PM
