Persistant P0441 solved - FYI
Persistent P0441 solved - FYI
Started getting a random P0441 about 8 months ago. Tested the purge valve and even though it tested fine, I went ahead and put in the Hyundai unit since it was cheap. Went away for a bit then came back around a few months ago and had to clear it every 2-3 weeks. It started coming back more frequently and this past week I would have to clear it daily. Checked the new valve today and it is fine. Then I looked in the hose running back to the canister and saw that it was a bit more than 1/2 blocked. The inner liner had separated and snuck back into the hose blocking the canister side of the valve. I cleaned it out with a pair of pliers (it was pretty stiff) and it looks like it fixed it. I will replace the hose at some point, but for now it seems to be working fine.
Pulled this out....
Pulled this out....
The following 2 users liked this post by Red5:
Discorama (05-20-2021),
The Deputy (03-18-2018)
Jared9220
01-28-2013 08:23 AM
