Persistant P0441 solved - FYI
Old Mar 17, 2018 | 01:52 PM
Red5's Avatar
Default Persistent P0441 solved - FYI
Started getting a random P0441 about 8 months ago. Tested the purge valve and even though it tested fine, I went ahead and put in the Hyundai unit since it was cheap. Went away for a bit then came back around a few months ago and had to clear it every 2-3 weeks. It started coming back more frequently and this past week I would have to clear it daily. Checked the new valve today and it is fine. Then I looked in the hose running back to the canister and saw that it was a bit more than 1/2 blocked. The inner liner had separated and snuck back into the hose blocking the canister side of the valve. I cleaned it out with a pair of pliers (it was pretty stiff) and it looks like it fixed it. I will replace the hose at some point, but for now it seems to be working fine.
Pulled this out....
Old Mar 17, 2018 | 04:15 PM
Saturnine's Avatar
Old Mar 17, 2018 | 07:02 PM
LR03NJ's Avatar
Elmono
LR4
May 9, 2024 05:03 PM
mr. choodles
Apr 5, 2020 08:06 PM
ROB99DISCOSD
Jan 27, 2018 04:43 PM
edgarf23
Sep 6, 2013 10:01 PM
baburhan
Oct 12, 2010 04:16 PM
