persistent dripping
Old May 15, 2018 | 10:17 AM
project_68's Avatar
Default persistent dripping
Hi.
so, I recently finished Mikes 100k maintenance list, and got my 02 back on the road after 3 years in storage! love this rover!
anyway, this is probably nothing, but wanted to see what you all think.
now that my driveway is completely free of stains and spills from the 100k maintenance service, I noticed the other day a dripping of clear liquid coming from about amidships. upon inspection, it looks to be coming from a rubber nipple located on the passenger side of the tranny hump close to the downstream o2 sensor harness connection.
Is this just a body drain port? seems to have been dripping from there consistently for the past several days.
if this is the case, is there a way to clean/blow out that port so whatever water is trapped in there clears more quickly?
after all that effort on the 100k+ tires+newkeys+door lock actuators, etc... I'd like to avoid rust if at all possible.
Thanks much!
Old May 15, 2018 | 10:40 AM
Ac drain I believe
Old May 15, 2018 | 10:49 AM
JUKE179r's Avatar
yep... Air Con drain. It's supposed to do that.
If it didn't drip, you'd have a soggy carpet. I know of this too well...
Old May 15, 2018 | 11:09 AM
Friday Night Disco's Avatar
AC drain, I cleaned mine out last year with a screwdriver and pick. I would recommend doing the same thing as a bunch of mud was stuck in mine and could have potentially clogged the drain and caused a back up.
Old May 15, 2018 | 11:24 AM
Best4x4's Avatar
I remove the dang nipples. They clog way to easy!! If a spider wants a bath they can crawl up it anytime they want & have a fun slip n slide kinda ride on the way out lol.
“If” you prefer to keep the nipples you simply squeeze it & it will pop out so you can clean them.
Old May 15, 2018 | 11:52 AM
A little twist after the squeeze helps with Tricky Dick's nipples
Old May 15, 2018 | 01:14 PM
Chemcorp158's Avatar
The Demon is currently sitting with the doors open and the carpet drying because of those nipples. I suggest keeping them clean. Dirty nipples are no fun.
Old May 15, 2018 | 04:01 PM
akrover90's Avatar
It took me a week to fully dry out my truck last summer. And I had to pull up all the carpets. I was amazed how much water the padding was able to hold.
Old May 16, 2018 | 11:01 AM
LR03NJ's Avatar
Love nipples.
GentlemanDriver
Sep 2, 2014 09:25 AM
Disco203
Aug 19, 2013 09:48 AM
br0keit
Jul 17, 2013 10:36 AM
lipadj46
Jun 15, 2009 10:19 PM
EVN137
Jul 15, 2007 09:27 AM
