Pics/diagram of sunroof drains?
Old Dec 18, 2012 | 10:00 AM
grandkodiak's Avatar
Default Pics/diagram of sunroof drains?
Does anyone have pics or a diagram of the sunroof drain system? just noticed my headliner on the right upper side is starting to droop, I think I remember someone saying the draings back up or clog and are in that general area?
Old Dec 18, 2012 | 10:39 AM
That is not from a leak, typical head liner issue.
Old Dec 18, 2012 | 10:56 AM
lr2001silver's Avatar
Banned
Headliners just sag, doesn't have anything to do with drain unless your seeing wet spots.
Old Dec 18, 2012 | 11:24 AM
hilltoppersx's Avatar
when you go to repair the headliner then you can clean the drain lines for the sunroofs and re-seal them to the gutter. see my write up in the tech section
Old Dec 18, 2012 | 01:11 PM
Just noticed it and its been rather wet out the last few days, didnt touch it though to see if it were moist. Not happening anywhere else, but for some reason I thought that might be the area the drain was.
Old Dec 18, 2012 | 01:14 PM
CANAMDiscovery's Avatar
Default Some sunroof drain pics
I did remove the headliner and sunroof drain trains to rebed the plastic drain inserts....
here are some pics of what it looks like under the head liner.
Attached Thumbnails Pics/diagram of sunroof drains?-photo.jpg   Pics/diagram of sunroof drains?-photo-3.jpg   Pics/diagram of sunroof drains?-photo-1.jpg   Pics/diagram of sunroof drains?-photo-4.jpg   Pics/diagram of sunroof drains?-photo-2.jpg
Old Oct 5, 2022 | 03:15 PM
macutan's Avatar
I have the same wet spots on the passenger side, how does the water get in there in the first place? My sunroof is ALWAYS closed!, wouldn't it be easier for me to seal around the sunroof rubber seal? is that where water usually comes in from?
Old Oct 6, 2022 | 01:33 PM
frostythor's Avatar
my D2 is 1999, I had a lot of water getting in wet carpets and wet headliner, I climb up and i could move the sunroof, 1/2 in left to right and front to rear, so I removed the headliner and removed both sunroofs cleaned and resealed the both I also removed the glass and removed its seal and resealed that then replace the glass, this was 2 years ago and it been OK since then the wet carpets was a hole just under the windscreen and a badly sealing grommet in the juar below the windscreen were the electric wire for the heated screen go through, I think if your main seal has gone the any water runs down the inside of the roof and drips down from just above the windscreen, it only took me a few daye to do the complete job, but several months to find the problem
Old Oct 6, 2022 | 07:51 PM
Discorama's Avatar
Check if the glass sits tightly on the rubber seals. Make sure, the screws holding the glass are tight. Check if the glass is centered (measure the gaps from above). If the glass is not centered, it might not seal well. You might see a small gap between the glass and the rubber seal from inside. This is how the water can get in, although the sunroof is always closed.
Old Oct 7, 2022 | 02:39 AM
frostythor's Avatar
Yes the glass seal can be difficult as you have 4 corners, I remov3d the seal, cleaned out the grove the applied a good coating of sealant the replaced the seal as fast as I could and shut the glass down tight to hold the eseal in place and let the sealer set
Columbiar
Nov 29, 2016 03:20 PM
Fairview
Aug 17, 2011 05:45 AM
Gerard
Feb 20, 2011 06:54 PM
srbaker
Dec 9, 2010 07:39 PM
nynole
Feb 26, 2008 06:04 AM
