Pictures of an exploded Joint that destroyed transmission
Old Feb 1, 2010 | 05:00 PM
unimoged's Avatar
Default Pictures of an exploded Joint that destroyed transmission
This 2002 DII with 80 K miles let go of its driveshaft taking out the transmission housing when the joint exploded. (( Bought it like this)). Luckily, found a used good transmission for 400 and a drive shaft for 100.
Attached Thumbnails Pictures of an exploded Joint that destroyed transmission-sspx0530.jpg   Pictures of an exploded Joint that destroyed transmission-sspx0531.jpg   Pictures of an exploded Joint that destroyed transmission-sspx0529.jpg
Old Feb 1, 2010 | 05:09 PM
hilltoppersx's Avatar
yeah. that happens. how much did you pay for it all busted?
Old Feb 1, 2010 | 05:16 PM
devildog01's Avatar
Alittle JB weld and some atf and you'll be good as new
Old Feb 1, 2010 | 05:45 PM
unimoged's Avatar
Originally Posted by hilltoppersx
yeah. That happens. How much did you pay for it all busted?
$ 1200
Old Feb 1, 2010 | 08:02 PM
make sure you have the new drive shaft rebuilt with greasable u joints and a new centering ball kit so it doesnt break and put a hole in your new used $400 tranny.
Old Feb 1, 2010 | 08:03 PM
Scott R's Avatar
We need start a club. Who's going to be the clever guy to build a plate steel shield that can be bolted to the t-case between the trans?
Attached Thumbnails Pictures of an exploded Joint that destroyed transmission-trans.jpg
Old Feb 1, 2010 | 08:28 PM
unimoged's Avatar
It is already done and rebuilt with grease fittings. But this double cardan joint design is archaic and pre-historic and it is disappointing that Land Rover continued to use this design all the way through the 2004 MY.
The double cardan joint cancels the angular velocity variation that a single U-joint cannot, but there are multiple newer, simpler and cheaper options that they could have adopted.
Nevertheless, its is a Land Rover and what else can I say!!!
Old Feb 1, 2010 | 08:31 PM
unimoged's Avatar
This is a clever idea and I am sure it will work.
On the other hand, I have been looking at building a drive shaft with a CV joint that will do a better job than the double cardan joint and it will require no grease since a CV joint has a boot that encases the joint and keeps the grease inside.
Old Feb 1, 2010 | 08:32 PM
NiteTrain's Avatar
DII with 80k miles for $1,700 and some elbow grease..not bad at all! way to go man.
Old Feb 1, 2010 | 11:19 PM
greg409's Avatar
Talking
What the heck ever happened to driveshaft hoops?
If I had a DII, I'd spend an hour and weld one up
Doesn't the carrier unbolt like my DI? - I'd put a 4-6" hoop off that, no wait, I'd probably
check it twice a year as I do with my DI, never mind. (No desrespect intended to anyone)
luck,greg
