A pillar: easiest way to remove?
Old Mar 22, 2008 | 11:00 PM
Hare's Avatar
Default A pillar: easiest way to remove?
I want to replace the tweeters in my A pillars but have had some issues removing them. I've tried a good ole panel popper but it looks to be connected in an unusual manner (not look the typical door panel). I've looked at the the rave CD but it didn't help me much. Any suggestions?
Old Mar 22, 2008 | 11:04 PM
Urban Panzer's Avatar
Default RE: A pillar: easiest way to remove?
Hi, Its simply clipped to the frame with metal springs clips (x 3). Is best to pull the door rubber / seal away, that helps to give you more access, then "carefully" lever it away.
The clips are positioned about 1 1/2 inches down from the top and 1 up from the bottom about the same distance, and one in the middle.
Start at the top one, try to get your "lever" to approx the middle / centre line of the trim as you lever it,It will come no probs. Sometimes just a good "tug" with 2 hands will release it.
Old Mar 24, 2008 | 12:40 AM
Disco2Guy's Avatar
I need to replace the driver's side on my D2 also. It seems the PO used the top of the pillar as a grab point instead of the handle to get in the vehicle and now there are some cracks up there. The tweeters are not installed currently but I have seen trim pieces with them for pretty cheap. If I get the tweeters can I just plug them in or is there wiring that needs to be added also?
Old Mar 25, 2008 | 01:16 PM
Hare's Avatar
The speaker diagrams on the rave CD show that the tweeters are wired to the front door speakers. I can give you a more detailed account once I replace the factory tweets with some aftermarkets.
bcolins
Sep 25, 2013 02:52 PM
me 2
Mar 18, 2013 07:17 AM
tweakrover
Dec 28, 2011 03:52 PM
losinov
Dec 16, 2010 07:03 PM
