Pinion seal-Rear
Old May 11, 2011 | 12:29 AM
discoboy's Avatar
Default Pinion seal-Rear
Is this a common failure on Discos? 03 D2 with 96k. I just noticed the wetness from the pinion seal this past Sat. Anyways, I will get a chance in the next few days to get it done, any tips or advice, or is it straight forward to replace?
Old May 11, 2011 | 02:04 AM
buick215's Avatar
No, it actually isn't a common failure. That is actually one of the few places where they don't leak. It is pretty straight forward to replace and I can't think of any tips other than checking the fluid level and maybe even draining and adding new fluid while you're at it.
Old May 11, 2011 | 09:34 PM
Check and make sure your axle breather is not clogged first.
I would hate to have you replace the pinion seal and then have it leak again a week later because the axle breather was clogged.
Mine leaked when I first got my truck, replace the axle breather and it has not leaked since.
Old May 12, 2011 | 12:36 AM
discoboy's Avatar
Thanks guys, I didn't think about that..my A/C drain tubes were plugged when I first got this truck so I guess I shouldn't be surprised.
ralphobell
May 11, 2014 08:11 PM
amaxson
Jun 26, 2011 06:59 PM
LRScott
Jun 2, 2009 08:37 PM
newdr
Mar 18, 2008 07:56 PM
garover
Feb 20, 2005 11:08 PM
