Piston Wont Budge
Old Jan 28, 2013 | 02:57 PM
jfall's Avatar
If you have channel locks, you can try to gently get it centered and get it back in.
The piston has to be skewed to the side by a degree or two.
Old Jan 28, 2013 | 03:54 PM
Or as a last resort, start the truck and gently apply brake pressure and blow the piston out of the caliper.
Old Jan 28, 2013 | 07:12 PM
Disco Buddy's Avatar
6th Gear
I managed to finally get the piston back in, thank you for all your help. I took the piston out and cleaned everything. However, I think the problem was that the piston was pushed out at a weird angle after I pushed the outer piston in (if that makes any sense). Once I angle the piston correctly I was able to push it in quite easily.
Now the brakes feels like mush though, looks like I am going to have to bleed the brakes :/
Old Jan 28, 2013 | 07:49 PM
jfall's Avatar
Make sure the seal in that calliper is not damaged.
Or you'll have streaky wheels with brake fluid on the wheels.
Old Jan 29, 2013 | 10:01 AM
6th Gear
Could that be a cause for the loose brake pedal?
Old Jan 30, 2013 | 06:55 AM
drowssap's Avatar
rebuild the caliper or get a rebuilt one. the reason I suggest that is:
1. the piston would not collase/never a good sign
2. your piston was cocked on the bore/ not a good sign
3. you popped the piston out of the bore/probably cuasing damaging the o-ring trying to get to back in.
cosmiccharlie
Jun 20, 2013 08:48 PM
robdis96
Feb 18, 2013 01:08 AM
ruffram
Oct 20, 2012 12:12 PM
twaszak
Nov 26, 2010 01:41 PM
flygirl92
Apr 29, 2008 03:48 PM
