Plastic cover that encloses the air filter?
Old May 26, 2010 | 11:08 AM
ragandhi's Avatar
6th Gear
Default Plastic cover that encloses the air filter?
Replaced my air filter last week. While taking off the black, plastic, cover with three clips that secures it down.......one clip broke. It still looks to be sealed, but I know it's not 100%. So two questions:
1) What is that plastic cover called?
2) How expensive is it and where can I buy one?
I'm afraid to even call Rosenthal Land Rover/Jaguar... they will charge an arm and a leg.
No check engine light on, so that's good. Sensors haven't picked up on it yet.
Thanks guys!
Old May 26, 2010 | 01:54 PM
chwelch's Avatar
8th Gear
Here's one on Ebay for $24.
http://cgi.ebay.com/ebaymotors/ws/eB...d=350347860331
Old May 26, 2010 | 02:20 PM
Danny Lee 97 Disco's Avatar
What year is your Disco? The airbox pictured on Ebay is from a DI with the inlet in the front, if yours is a DII it is different with the inlet on the outboard side,coming in from the front wheel well area?
Mine is a DI, a friend has a DII. I noticed the difference in the air inbox when we parked them side by side and did some under the hood comparisons.
I am not sure whether you really need a 100% seal on it anyway, that only lets a little more air in. I don't see how that can be a problem. What do you more experienced guys think?
Old May 26, 2010 | 02:55 PM
yloDiscoII's Avatar
Stay away from the dealer, there are plenty being parted out that you can pull from and save some money.
You're probably fine, 3 clips should hold it tight. In addition to that eBay link, you can also check out junkyards or Craigslist for someone parting out locally for a replacement...
Old May 26, 2010 | 03:17 PM
ragandhi's Avatar
6th Gear
Sorry, I totally forgot to mention that my car is a DII, 2003 w/ 69k.
Old May 26, 2010 | 07:20 PM
Man this happens alot on DII's.
The only problem with it not being 100% sealed is that the seal is broken after the air filter, so it will suck in non filtered air, which aint good.
Old May 27, 2010 | 12:37 AM
You beef up yjre seal with some good weatherstripping type stuff.
Southern Bawb
Apr 18, 2015 08:05 AM
hhalimi
Jan 29, 2012 11:43 AM
minsane
Feb 16, 2011 03:11 PM
Kswin
Apr 11, 2010 06:56 PM
brw1982
Mar 15, 2008 02:33 PM
