That plastic leaking t fitting
Old Jul 15, 2018 | 09:45 AM
Mcdan's Avatar
Default That plastic leaking t fitting
hello all. First post here. So the coolant bleeder screw broke in half. Ran to the hardware store and picked up an m-10 bolt to get home. Now I’m seeing a hair line crack in the t itself. Ordered upper hose assembly from ab and should be here Monday.
So the question is: how much coolant is going to come out when I pull the hoses? Is there a drain **** to avoid a big mess?
dan
Old Jul 15, 2018 | 11:55 AM
dtmbinb's Avatar
No way to avoid the mess. Just pull the hoses. You might need 2 liters to refill and properly bleed.
Old Jul 15, 2018 | 12:05 PM
Mcdan's Avatar
Thanks! I was afraid of that. Well that’s what’s it going to be then. Maybe some sort of tray under the car will help?
Old Jul 15, 2018 | 12:16 PM
Best4x4's Avatar
Stick a shopvac on the upper T and suck as much out as possible. It helps prevent a huge mess.
Old Jul 15, 2018 | 12:38 PM
Jeff Blake's Avatar
I have one of these brass bleed screws https://www.ebay.com/itm/NEW-Brass-C...sid=m570.l1313
Old Jul 15, 2018 | 12:45 PM
dtmbinb's Avatar
I use a brass bleed screw as well. No more broken or stripped plastic screw.
Old Jul 15, 2018 | 12:49 PM
Mcdan's Avatar
Thanks, Jeff. Unfortunately it’s too late for that. The T itself has a hairline crack in it. So the whole thing gets replaced. Besides that I fear expansion rates might be different for the brass vs the plastic housing. I would like to know how yours is fearing as time passes.
Old Jul 15, 2018 | 01:01 PM
dtmbinb's Avatar
I've run the brass screw for over two years. It's a better option.
Old Jul 15, 2018 | 01:03 PM
Jeff Blake's Avatar
About two years as well, no issues.
Old Jul 15, 2018 | 01:16 PM
Mcdan's Avatar
Great to know! Then that’s the way to go after changing out the T. I’ll get that ordered. I’m thinking that T’s been there a long time and is pretty brittle. A fresh one will be more flexible?
