Plastic shield under engine - any reason NOT to remove it
Not sure what the shield under the engine is, but is there a reason not to remove it permanently. Other than a little aerodynamics and fluid/drip catching, I can't see a real need for it.
Thanks,
Dave
Thanks,
Dave
It isn't really important but I am not a fan of tossing out parts so I have kept mine. It might also protect the bottom from any road debris. It doesn't cause me any problems when I do the oil changes and I have only had to remove mine once and that was to replace the lower coolant hose.
just toss it if you like. might need a dremel or something of the sort. not sure if anyone has done underhood temp readings before and after, but i gotta think it would at the very least get some cool air swirling under the hood a bit at speed. also makes it much easier to inspect and get to other things under the chassis. in terms of guarding the bottom of the engine when going over rocks it is fiberglass or plastic fiber and offers little to no real structural defense.
2003 Discovery 129K with High Miles service complete
