Please check my Coolant Temp numbers
Old Aug 27, 2018 | 08:32 PM
Richard Gallant's Avatar
Your temps are what see with a 180 thermostat, I have an issue when hits around 85 - 90 outside and I am going up very steep grades at slow speed my temps run up to around 208. Turning the heat on and dropping an extra gear to 2nd made that largely go away, top of the hill with my clutch fully engaged my temps have dropped to as low as 181 for a couple of minutes or so before returning to normal as I coast along.
Normally I run 188 to 194 around town, 186 to 190 hi way flat 188 to 197 hi way on hills at around 65 mph
Old Aug 27, 2018 | 08:37 PM
CollieRover's Avatar
Originally Posted by attworth
Hello all. I’m new to the Rover world so I just wanted someone to look at my numbers and let me know if I’m in the right place.
While idling for about 20 minutes in the school pick up line today, AC blasting, 100* outside, it creeped from 194 to 215 before I shut off the AC and it slowly dropped back down.
Normal idle without AC it won’t go above 200.
Highway cruising at 65-70 mph it’ll float between 185 and 194 depending on hills.
Around town it’s about 190-194.
I replaced the entire cooling system minus the heater core and fan/clutch a few days ago. I’m now running green coolant and a bottle of water wetter, as well as the grey 180* stat. System was held in vacuum with a Robinair tool for a few minutes before filling with said coolant, so there should be no air.
I planned to replace the fan clutch, but the one in the truck is integrated with the fan.
My concern here is that I should be able to idle theoretically indefinitely with the AC cranked if the system is operating as it should. Other than the fan and clutch, I don’t see any other concerns here. Is this just a “Rover-ism” til I go inline t-stat and/or e-fan? The current clutch seems fine by the way, stiff to spin.
Thanks all!
i have had a similar issue with a/c, regrettably, no satisfactory reason why it happened. A mechanic fixed it, but I did not get to speak to the technician. It still sometimes does get hotter for seemingly no reason with a/c.
Old Aug 28, 2018 | 11:05 AM
dgi 07's Avatar
177 - 185 on highway
188 around town
190-197 with ac on on highway
201 - 204 with ac on around town
I get low coolant temps with low ambient temperatures. High coolant temps with high ambient temps and high under-hood temps.
New Rad, inline thermostat and AC condensor fan. No water wetter, just Mercedes green/blue coolant.
2001 with 106k on the clock
Old Aug 28, 2018 | 11:22 AM
Best4x4's Avatar
AC condensor creates extra heat when the AC is running, the efan helps, but it will not stop warmer air to pass thru the transmission cooler, oil cooler, and the radiator.
Old Aug 28, 2018 | 02:55 PM
dtmbinb's Avatar
Same here. When outside temps are above 85-90, my idle, uphill, and 70+ highway can go up to 206-210. Below 85 outside, I never break 204. I always have the ac cranked, so it adds extra heat. I say don't worry unless is gets over 215 and does not go down when moving or revving in neutral.
Old Aug 28, 2018 | 03:22 PM
Dave03S's Avatar
Same here and I have an entirely new cooling system with e-fan. Only happens above 85 degrees or 70mph and above 80 degrees at the same time.
Old Aug 30, 2018 | 05:28 PM
attworth's Avatar
Just thought I’d post for future readers. The new fan and clutch definitely fixed my issues. I’m not seeing over 204, with 100+ ambient temps and AC blasting. Also my highway temps are down between 183-190.
Im a happy camper.
escott16
Jul 6, 2019 09:48 PM
DISCOFETA
Apr 5, 2019 07:44 AM
NickAdams
Aug 13, 2015 09:51 AM
New96DiscoOwner
Aug 4, 2015 08:56 PM
04duxlr
Jul 16, 2015 03:31 PM
