Please help, 03 motor porblem
Old Jul 1, 2015 | 06:40 AM
  #21
drowssap's Avatar
that's one of the better oil pump explosions I've seen.
you should add a front cover to your list as well as a timing chain set.
I would inspect that front cover very closely, I would be surprised if you didn't need another.
If your looking for cheap gasket sets eBay is loaded with them, and cheap radiators.
Old Jul 1, 2015 | 08:33 AM
  #22
abran's Avatar
The pressure would definitely escape through the path of least resistance. So you would need to pressure test again once the rad leak is fixed.
Originally Posted by chubbs878
Abran, if you are to test pressure with an opening that large in the radiator would it fail to show leaks in tighter places like, I don't know, head gaskets for example?
Old Jul 1, 2015 | 08:35 AM
  #23
abran's Avatar
He had front cover on his list, but timing chain set is a good call, while you are in there...
Old Jul 1, 2015 | 08:55 AM
  #24
drowssap's Avatar
so he does, my mistake
Old Jul 1, 2015 | 02:46 PM
  #25
WNYErikDiscoII's Avatar
Former Sponsor
Originally Posted by abran
I would say Lucky8.
Thanks buddy.
As per your list, here is what I have in stock for forum member pricing. All brand new parts.
Water pump - STC4378 - $45/with gasket
Bolt Kit - $7
Front Cover - LJR000220 - $400 includes new oil pump and front oil seal
Timing set - $52
Includes the following:
Chain - ERC7929 - $13
cam wheel - ERR7375 - $17
crank wheel - ERR2958 - $7
Front cover gasket - ERR7280 - $5
oil tube pickup o ring - ERR4794 - $1
oil pan gasket - LVF100400 - $9
Nissens Radiator - PCC000710 - $190
Free Shipping on everything.
Old Jul 1, 2015 | 04:20 PM
  #26
abran's Avatar
^ Wow, thats affordable. I checked my wholesale account at Worldpac and they are way more expensive.
Old Jul 2, 2015 | 06:04 AM
  #27
drowssap's Avatar
they are good prices,
its amazing how much front cover have come down.
But there is an aftermarket cover out now, i dont know it that is the LR # number
Old Jul 20, 2015 | 10:49 AM
  #28
Bayer's Avatar
Update; Thanks Eric! saved me a crap load of $ on parts, they arrived Friday and I dropped them off at the shop today.
Its going to be a few days before we get everything installed, there's a jeep on the lift with a rod hole in the block, oops.
Ill let you fellows know how it goes.
1999SE40
May 16, 2014 06:48 AM
BigDogg
Jul 4, 2012 09:24 AM
me 2
Jun 17, 2012 07:24 PM
ColeRover
Feb 9, 2011 07:05 AM
