Please help...Front driver and passenger carpet very wet
Hi,
Where the @#$% are the drains from the AC?? I think they're clogged or something or be another issue that the front driver and passenger side is very wet and here in Puerto Rico is not raining. I fix something and the next week is another issue....Damn it!
Not easy to spot the drains. Bring a flashlight. They are in the transmission tunnel on either side of the transfer case. They are black rubber nipples. Squeeze them.
Taken out of context, that sounds awesome.
Make sure the truck is cooled off before you check the drains underneath. They are right next to the cats and those are extremely hot. I took a pair of scissors and cut the nipples back a bit to help prevent them from clogging up so easy. Also stuck a wire hanger up the tube to get a bunch of gunk out. Make sure your face isn't directly under it. You'll get covered with nasty ****! 😕
bcolins
Jun 29, 2015 07:22 PM
Spencerfitch
May 3, 2010 02:56 PM
