Please help...Front driver and passenger carpet very wet
Old Nov 27, 2014 | 10:00 AM
Wachy's Avatar
Angry Please help...Front driver and passenger carpet very wet
Hi,
Where the @#$% are the drains from the AC?? I think they're clogged or something or be another issue that the front driver and passenger side is very wet and here in Puerto Rico is not raining. I fix something and the next week is another issue....Damn it!
Old Nov 27, 2014 | 02:01 PM
gtagg's Avatar
problem may be heater core you can remove the panel below glove box and check for a water leak. windows steaming up?
Old Nov 27, 2014 | 02:19 PM
G150driver's Avatar
Not easy to spot the drains. Bring a flashlight. They are in the transmission tunnel on either side of the transfer case. They are black rubber nipples. Squeeze them.
Taken out of context, that sounds awesome.
Old Nov 27, 2014 | 03:09 PM
drowssap's Avatar
Are you missing coolant? If so possible a heater core. If not see above.
Old Dec 3, 2014 | 11:26 PM
mattmo78's Avatar
Make sure the truck is cooled off before you check the drains underneath. They are right next to the cats and those are extremely hot. I took a pair of scissors and cut the nipples back a bit to help prevent them from clogging up so easy. Also stuck a wire hanger up the tube to get a bunch of gunk out. Make sure your face isn't directly under it. You'll get covered with nasty ****! 😕
JasonjCook
Jun 18, 2013 11:09 AM
Spencerfitch
May 3, 2010 02:56 PM
Princess
Sep 15, 2009 08:02 PM
knac1234
Jul 25, 2009 09:56 AM
